Should my Scag roll when shut-off?
DanWeir
New member
Joined
Jul 29, 2026
Messages
3
City & State/Province
Virginia
I just purchased a used Scag V-ride 52" stand-on mower. Something that feels a bit scary to me is that when I stop on a hill, the machine will continue (slowly) to roll unless I actuall "bump" the drive to the reverse. If I shut the machine off on level concrete I can also push the machine by hand, wheels rolling. Theres resistance, not "free wheeling" but it still rolls. I've checked the dump (bypass ) valves on the pumps and they are tight. Do other mowers behave this way? Thanks
A stand-on rolling on a hill would make me nervous too. That hydro drive resistance you're feeling instead of true free wheeling sounds like it's just doing what it's built to do but the part where it creeps on a hill after shutdown seems worth keeping an eye on. Is this happening on any incline or just steeper ones so far?
My back is real messed up right now so I have not been able to use the machine enough to get real familiar with it but it was on a steep incline that it happened. The tires started sliding a little, I panicked and let off the dead-man switch to kill it but it kept rolling down the short steep slope, across about 3-4' of relatively flat and into some bamboo. Not FAST but more than what I would call "creep". I do know that the short time I've used it, on a slight incline, it does not come to a complete stop if the forward levers are pulled back to a neutral position - I have to "bump" the reverse position to fully stop motion.
Back
Top
